				BDF decimator problems
				Posted: Thu Mar 22, 2007 8:16 pm
				by juliag
				I am trying to downsample my data from 2048 Hz to 512 Hz with the BDF decimater.
This seems to work fine, except that all the data is 'cut off' at 2552 sec. After that the data appears as  flat lines or nothing.
The files are still the same length as before, except that there is no data in the last part.
Julia Grieser
				Posted: Fri Mar 23, 2007 7:15 pm
				The current file tools (compiled in LabVIEW 7.1) are not able to process the BDF files beyond the 2 GB point. I have new versions ready compiled in LabVIEW 8.2 (which works with 64 bit array indexes), and these can handle much larger file lengths. The new tools will be put on our website during the coming week. Please email me if you need the tool sooner.
				Posted: Thu Mar 29, 2007 4:08 pm
				The updated tools are now available for download from our website, see
http://www.biosemi.com/new.htm . Please let me know if any problem remains.
				bug Decimator
				Posted: Fri Oct 16, 2009 4:16 pm
				by flor
				Hi, I'm using BioSemi decimator to downsample a 1000Hz file to 256Hz. The file size is 200Kb and Decimator, whenever I try to use it for this file, it pops up an error message saying "invalid file length". Is there a file length limit for Decimator to work? Thanks!!
				Posted: Fri Oct 16, 2009 4:34 pm
				There is no file limit in decimator. You file seems to be corrupted, please check with BDFreader.
				Posted: Fri Oct 16, 2009 4:46 pm
				by flor
				Hi again,
I could open it with BDFreader, but a warning message appears that says "file size in header does not match actual file size", I click on continue and I could see the file...
				Posted: Fri Oct 16, 2009 4:54 pm
				Use FileCropper to repair the file header (crop to the file length indicated in BDFreader).
