TCP connection
Posted: Wed Sep 21, 2011 3:11 am
				Hi
I'm new to ActiveView and trying to use the TCP Client. the client used is ActiveTwoClient_8. I use a router to connect two computers, I don't konw if it has a problem to do like this. Once I start the program, there is a error : the network operation exceeded the user specified or system time limit.
If I should connect two computers using a cable directly.
help!
thanks very much!
And the error will also appear when I use TCP server on the same PC.
help!
thanks very much!
