				Synchronizing EEG with a long signal
				Posted: Sat Mar 21, 2015 12:06 am
				by victorminces
				I would like to present the subject a long sequence of stimuli (20 mins) and have it perfectly synchronized with the EEG activity. What is the best to do this? In other systems I have used an EEG channel to "record" the stimuli simultaneously with the brain data. It would be ideal if I can do something similar with your system.
Victor
				Re: Synchronizing EEG with a long signal
				Posted: Sun Mar 22, 2015 3:04 pm
				Posted: Wed Mar 25, 2015 11:22 pm
				by victorminces
				Thank you. But I don't think either of these options can work. Those are options for using triggers. What I want is to record a long speech signal together with the brain in order to have them perfectly synchronized. Do you have any other suggestions?
				Posted: Thu Mar 26, 2015 1:41 am
				Purchase our microphone and ERGO input, see
http://www.biosemi.com/accessoires.htm
				Posted: Thu Mar 26, 2015 9:45 pm
				by victorminces
				Thanks. But our speech signal is not recorded through a microphone but is "pre-recorded" and presented through a computer's audio output. Can I connect the computer's audio output through the ERGO input?
				Posted: Fri Mar 27, 2015 12:22 pm
				You should never connect a computer to an ERGO input since that would short the galvanic isolation of the front-end (refer to warnings in the manual).
Connect the audio signal to an Analog Input Box, see
http://www.biosemi.com/aib.htm. You will then have the audio signal as an extra analog channel on screen and on BDF file.
				Posted: Mon Mar 30, 2015 7:50 pm
				by victorminces
				Thanks, I think that should work.
				Posted: Tue Dec 10, 2019 2:29 pm
				by matfra
I would like to revisit the discussion above to get more clarity on the possibility of recording audio stimuli along with the EEG signal, in order to get a clear record of the timing of auditory stimuli.
How could I record two auditory channels (subject microphone and auditory stimulation) synchronized with the EEG signals? As I understand from the discussion above, this is only possible with the AIB, correct? Does this solution allow two auditory channels? And how do I get my audio signal (let's say from a simple audio jack) to the AIB?
