We have Windows7, 64bits.
I tried the correct beta version, with the correct driver, and with the "LabVIEW runtime engine 8.6.1".
It doesn't work. Whenever I hit "Start" in Actiview it takes 5 to 10 seconds, the green light that says "data" in the "data box" blinks twice and then an error message shows up: "Error 5000 occurred at No Incoming Data...".
I'm certain that the Optical fiber and the USB cables are fine. They work with our old Windows.
Also, we have another Windows7 with the same setting and the same Actiview and driver versions, and it works fine.
Any suggestions?
Thanks.
Actiview installation
anavarrocebrian
anavarrocebrian
The old driver does not work on Vista/7 machines, so you will have to upgrade the USB-receiver firmware.
Please contact your local BioSemi representative to arrange a firmware upgrade for the USB-receiver.
