L.S.,
I am currently working on a surface EMG experiment, using the Headbox with 32 Active TouchProof connectors, of which I use 16 channels with the flat type electrodes.
Unfortunately, this means I am unable to use a bipolar view as you can do with the EX1-8 channels, where you can see what the signal of EX1 - EX2 looks like.
For example, it would be very useful to me if I can check what the signal looks like if I subtract A1 - A2, A3 - A4, etc.
Is this in any way possible?
Kind regards,
Elisabeth Huis in 't Veld
Tilburg University
Bipolar view when not using EX1-8
Huisintveld
Bipolar leads can be displayed one-by-one by using the "free choice" options for "channels" and "reference" in the monopolar tabpage (e.g.: select chan A1 and ref A2 to display A1-A2).
Using the bipolar tabpage for other channels than EX1-EX2 requires some simple code changes in LabVIEW. Since ActiView is fully open source, the user can easily adapt the program to his special needs.
Huisintveld
I wouldn't call it easy, I installed LabView and spend the better part of my day trying to work it out but alas.
(I also can't find a good manual for complete beginners like myself.)
If anyone has an idea on how to accomplish this I love to hear it!
Until then I will manually check every channel as you suggested.
Sincerely, Elisabeth Huis in 't Veld
Huisintveld
Thank you so much for your patience, but I don't even know how to get to the part in the software where you can change this. If I try to import a library I don't see the Ref-Bip-New4.vi, and if I open Ref-Bip-New4.vi I don't see where I can change the channel numbers, and the Call Library function is beyond my comprehension as well!
I am sorry for my utter lack of knowledge concerning any of this!
