Hi everybody.
We are using Eprime to send trigger to ActiView. I am aware that this is probably more a Eprime than a Biosemi question, but maybe somebdy of you came across the same problem.
The trigger send from Eprime via the parallel port work perfect for stimuli; I can see them all in ActiView. However, I do not know how to program Eprime so that all the responses/ button presses a subject make during the experiment get send to Actiview as a trigger. Can anybody help? It would be highly appreciated.
Gregor
						Response/ button press trigger from Eprime to ActiView
Re: Response/ button press trigger from Eprime to ActiView
I realize that this is an old post, but I'm currently having the same problem with E-prime. I can sent event triggers with no problems, but I cannot seem to send response triggers. I especially need to sent the accuracy variable for the response to ActiView, so that I can remove incorrect trials before analysis. Did you find a solution to your problem?
