Telegärtner trigger cable
danfour
Post by danfour »
Dear Biosemi forum,
We have 3 biosemi eeg units in our research lab, the latest of which we somehow bought without the parallel trigger cable.
From the previous devices, apparently we had gotten a different (extra) cable that seems to work, details from the package:
Telegärtner L00816A0001 Rangierkabel (FO cable) 62,5/125 2x T-ST Stecker (connector) 10.00m.
While the pins look a bit different the input/output heads look the same, also the people operating the device report that trigger codes are coming through.
I just wanted to check that this device is somehow approved, maybe where it might have come from and whether we can just substitute it in for our new machine.
Any advice would be appreciated.
Re: Telegärtner trigger cable
The "Telegärtner Rangierkabel" is the optical fiber, not the trigger cable.
If the triggers work, than you are using the proper trigger cable.
Coen (BioSemi)
