I'm using Biosemi to record EMG and I need to visualize the event related average after every trigger. However, with our current setting, this is possible only after odd trigger numbers (e.g;, 129, 131, 133 and so on) but not after even numbers. Could you please suggest me how to solve this problem?
Lara
select trigger in Event Related Average window
Re: select trigger in Event Related Average window
Trigger line 1 is High for all odd triggers while trigger line 2 is High for all even triggers. So, select Trig1 OR Trig2 to sweep on all triggers.
