using an old version of Actiview
nava
Post by nava »
Hello
In the past (2004) we have added a self-made module to the Actiview software. Then it worked prefectly with the Biosemi we used at the time. I am now trying to use this exact software with a relatively newly bought ActiveTwo Biosemi machine.
I get the following error:
Error 5002 occurred at Synchronization Lost
or
or
USB driver not properly closed on exit (restart LabVIEW and ActiVIEW)
I assume its connected to the fact I am using old saoftware with an new machine, but the problem is that I need to use it for that module...
is there any simple advice how to make the old software compatible?
thanks, nava
The new system is a Mk2, whereas the old system was probably a Mk1 (also viewtopic.php?t=270). The difference between Mk1 and Mk2 is the number of channels in each speedmode, see http://www.biosemi.com/faq/adjust_samplerate.htm and http://www.biosemi.com/faq/make_own_acq ... ftware.htm). Current ActiView switches automatically between Mk1 and Mk2, according to a marker in the trigger channel (see http://www.biosemi.com/faq/trigger_signals.htm). Your old software probably only supports Mk1.
I would recommend to integrate your own modules with current ActiView. Alternatively, you should change the number of channels in you old software (for example, speedmode 4 should be changed from 258 to 282 channels)
