ActiView Lite
ActiView Lite
There doesnt seem to be a ReadMe for the Actiview Lite software. Could someone tell me how it works, what its supposed to do, and whether or not this can act as a server?
Please read viewtopic.php?t=65
ActiView Light only contains the basic acquisition code, the output is a 2D array of ADC values (rows are channels, columns are successive samples). You can use this array as input for your own signal processing code.
Standard ActiView has the options to sent the data over a computer network via TCP/IP. You you can of course add this part of the code to ActiView light to build a lean server (without display and file save options).
