marialaura
marialaura
marialaura
Post by marialaura »
Hi, I'm trying to use the TCP Client ActiveTwoClient_4exe
I met a problem when trying to start the TCP Client application with Labview 8.2 Runtime.
Unable to locate the LabVIEW Run-Time Engine.
ActiveTwoClient_4 requires a version 7.1 (or compatible) LabVIEW Run-Time Engine. Please contact the vendor of ActiveTwoClient_4 to correct this problem.
I saw that others experienced the same problem...where can I download the new version of ActiveTwoClient?
Thanks very much to all,
Maria Laura
The current TCP client is only made available as Virtual Instrument (not as executable) running under LabVIEW 8.2. The client VI is meant as a basis for further LabVIEW developments.
You can run the old client executable with RTE 7.1 (ftp://ftp.ni.com/support/labview/window ... imeEng.exe). However, since the source code of the executable is not accessible, there is not much else you can do with it than check that it works.
