Hi
I need to send triggers from a "testing laptop" to mark events on the EEG trace of an "EEG laptop" using BioSemi/Actiview.
The problem is that the testing laptop does not have a parallel port to connect with the USB interface box throught the "trigger cable".
The “BioSemi USB trigger interface” would apparently solve the problem. However I have read that it works as a serial port. In general I see people talking about "paralell ports" when they want to send triggers / markers.
I wonder whether I can use “BioSemi USB trigger interface” cable to send event-markers from the testing laptop to the EEG trace.
Many thanks
Tiago
Using “BioSemi USB trigger interface” for sending triggers/mark events in EEG trace
louroprata
