Our team is considering purchasing a biosemi for use in an existing faraday cage. What cables need to go penetrate the wall for the use of the biosemi system? Is it just the fibre optic (when used with battery power)? Or are there additional triggers via the parallel port? (I can't tell from the info on the main page.)
If anyone can help with specifications for the cables and plug types that'd be a great help!
Thanks all!
sjs
Installing in a Faraday Cage
Re: Installing in a Faraday Cage
Only the optical fiber goes through the cage wall. You can use an optional fiber coupler (search for st-st coupler)
The triggers go to the USB receiver (near computer) outside the cage.
