Trigger Data from TCP/IP
supat
Post by supat »
Hi, I am developing a MATLAB program that receives data from Actiview TCP/IP broadcast. I have successfully decoded TCP/IP packet and confirm that EEG data were decoded correctly.
However I got values I do not understand for the trigger data. For example, one of the decoded value from trigger channel is -1996490240.
The trigger was sent to BioSemi in form of binary-encoded decimal where each trigger channels represented 1 bit.
Also, according to my experiment design, interval between each trigger is 2 seconds, but by plotting signal from trigger channel, the value seems to change in 1 second interval.
I would like to ask what is the proper way to decode and interpret trigger signal received from Actiview TCP/IP?
Supat
Re: Trigger Data from TCP/IP
The trigger are bit 8-23 of the 32 bit integer, see https://www.biosemi.com/faq/trigger_signals.htm (ignore bit 0-7, bit 24-31 are status bits)
supat
Post by supat »
Thank you for your reply. It solved my problem.
