Differences between decimater utility and Python
dgfitch
Post by dgfitch »
The decimater utility seems to be doing something beyond simple decimation, but we can't find further documentation. When we compare its output to equivalently decimated files ran through Python libs with a fifth order sinc filter, things look noisier. Almost like the decimater is doing an extra smoothing pass, beyond the documented sinc filter.
I've uploaded some comparisons: http://brainimaging.waisman.wisc.edu/~dfitch/biosemi/
For example, comparing inside BDFReader:
The "decimater" output:
Python output:
Re: Differences between decimater utility and Python
The decimator tool does just apply a 5th order cascaded integrator-comb (CIC) filter, no extra filtering/smoothing. Inspect the (open-source) LabVIEW code for confirmation.
dgfitch
Post by dgfitch »
Thanks Coen.
You may want to update the downloads page which just says "fifth order sinc filter" and doesn't mention CIC.
Robbie303
Post by Robbie303 »
The information on the website describing the filter has been updated:
"A fifth order cascaded integrator-comb (CIC) filter"
