Different event codes (triggers) in EEGLAB
DrCri
Post by DrCri »
Hello everyone,
After reading several posts about it, I am not sure how to fix my problem with triggers.
Currently I send triggers from Python through the serial port.
During the session I can perfectly visualize all the codes (triggers) in the continuum, but when I open my dataset in EEGLAB the codes are completely different.
The waves and everything else is fine, the problem is with the event codes.
In fact, I don't even know if these "new codes" correspond to the original events I programmed : for instance, instead of a 2 a 64514 appears.
I'd like to find out why this is happening and how to fix it, any help is really welcome.
C
Re: Different event codes (triggers) in EEGLAB
- Use the ""analog" display mode to inspect the 16 separate trigger lines.
- Use positive logic: pull all 16 lines low between the triggers.
- To see the same numbers as "decimal" display mode: split the 16 trigger bits in two 8-bit groups.
