Is this the problem of battery?
biozhd
Post by biozhd »
I found an old BioSemi system in the laboratory, and tried to use it.
At first, I updated the firmware to 4.0. After firmware updated, I can see "RECEIVER02" in Win10 system.
But when I connected all the wires and tried to use ActiView read data, it showed an error:
"Error 5000 occurred at No Incoming Data
ADC-box power is off
or
Optical fiber is disconnected"
I'm sure the optical fiber is connected.
When I turned on the battery, only the battery "on/off" button was green, all the other lights were off.
What should I check in the next step?? Thanks.
Re: Is this the problem of battery?
Does the second battery work ?
Check the fuse of the battery. If OK, then replace the internal cells.
biozhd
Post by biozhd »
When the second battery connected, the "shutdown" button was red, and the system did not work.
The fuse was OK in both batteries.
What should I check in the next step? Thanks.
You probably left the batteries too long (several months) is a discharged state. Always charge the batteries before storing and recharge them every few months.
The cells can sometimes be recovered with a few charge/discharge cycles. If not, then contact your local BioSemi representative for replacement of the battery cells.
