Hello, is it possible to define in code the number of channels the ActiView software connects to?
My intention is to run a client that requests the data from the software but I want to be able to just run
the client without manually defining the number of channels.
Best regards, Dor.
Defining in code the number of channels
Re: Defining in code the number of channels
The above is in principle possible by modifying the (open source LabVIEW) code of ActiView.
Note that you can save the settings (including TCP/IP selections) in the CFG file.
OK, thanks a lot!
Dor.
Dor.
