64 channels with 16KHz sampling rate?
Fran_Lop
Post by Fran_Lop »
Hi all,
I was wondering if there is any biosemi that can record 64 or more channels at 16KHz sampling rate. I checked this page (https://www.biosemi.com/faq/adjust_samplerate.htm) and saw that AD-box model MK2HS 'High-Speed' should be able to. Could you please confirm that is correct? Also, any opinions or thoughs about your experience with it would be much appreciated.
Fran
Re: 64 channels with 16KHz sampling rate?
AD-boxes can indeed be reprogrammed with HighSpeed firmware to allow 128+8+sensors channels at 16 kHz sample rate. Production date of the AD-box needs to be 2010 or later (serial ADC16-XX-XXXX or higher), the upgrade is free of charge. Older AD-boxes (ADC12-XX-XXXX or lower) need a new motherboard and connector board to allow the upgrade (extra costs).
Daisy Chaining (hyperscanning) and use of the Analog Input Box (AIB) is not possible with HighSpeed firmware.
Fran_Lop
Post by Fran_Lop »
Thanks so much, this was very helpful!
