How Can I Verify That ActiveTwo USB-Receiver 5.1 Is Receiving Triggers from PsychoPy 3?
pchs0114
Post by pchs0114 »
Hello all,
I'm currently utilising PsychoPy 3 to programme an experiment and am employing an ActiveTwo USB-Receiver 5.1 to receive triggers. Within my PsychoPy script, I'm using `byte_x` to set the value of these triggers.
Has anyone worked with a similar setup? Could you please advise me on verifying that the ActiveTwo USB-Receiver 5.1 receives the triggers I've set in PsychoPy? Any troubleshooting tips or tools for checking the status of the triggers would be most appreciated.
Many thanks in advance!
Re: How Can I Verify That ActiveTwo USB-Receiver 5.1 Is Receiving Triggers from PsychoPy 3?
If the triggers are received, then they are shown in ActiView.
pchs0114
Post by pchs0114 »
Thanks for replying. I know ActiView shows if triggers are received, but it doesn't specify which one—like trigger 1 or 2.
Select the "analog" trigger format and trigger line 1-16 are displayed as colored dots/bars. Select the "decimal" trigger format and the triggers are displayed as two groups of 8 bit numbers.
pchs0114
Post by pchs0114 »
HI,
Thanks! The problem is solved.
