How (if possible) do I use an alternative to Presentation/EPrime for stim presentation, such as Matlab (w/ psychophysics toolbox)?  I assume that I just need to figure out how to pass event codes to the Biosemi inputs?  Also, while I can use a PC if necessary, is there any way to do this on a Mac, which has no parallel port?
thanks,
-Steve
						using matlab + psychophysics toolbox for presentation
				hello
				stevef
matlab -> biosemi
Haven't gotten any responses yet, but will post the answer here if I ever get one.  Given Matlab's popularity, someone must've solved this.
-Steve
						-Steve
Bits++
For Mac / MATLAB / Psychophysics Toolbox users.  See Bits++ by Cambridge Research at http://www.crsltd.com/catalog/bits++/.  This is a solution for precise video and digital IO from a Mac or a PC.
							Lloyd Smith
lsmith@cortechsolutions.com
here's a description on how to set up triggers which is used within psychtoolbox:
http://psychtoolbox.org/wikka.php?wakka=FaqTTLTrigger
MATLAB API for recording direct from ActiveTwo
If you are interested in an open source MATLAB API for ActiveTwo, see this topic viewtopic.php?p=2049#2049.  Thanks.
							Lloyd Smith
