Modify ActiView Configuration
bista
Post by bista »
I was wondering if there is a way to configure the ActiView configuration file to show differential sEMG channels instead of bipolar EXG (EXG1-EXG2) in the Bipolar tab of the application.
Re: Modify ActiView Configuration
The above is not a standard option in ActiView that can be enabled with a CFG setting. Bipolar display for all channels would require changing the (open source LabVIEW) source code.
