Real-time processing of EEG signals from Active3
Hyosung Joo
Post by Hyosung Joo »
I attempted to perform real-time processing of EEG signals using LabStreamingLayer (LSL), but encountered an issue where the Active3 system could not link to LSL, resulting in the error: "Could not link to the amplifier: Ring buffer handshake with BioSemi driver failed unexpectedly."
Is there a way to resolve this error? If not, are there alternative methods for real-time processing of EEG signals from the Active3 system using MATLAB programming?
Re: Real-time processing of EEG signals from Active3
ActiView for ActiveThree can stream the data from the ringbuffer via a TCP/IP connection. You can consider to develop a MatLab client to read this real-time data stream.
Email to info@biosemi.com for the latest ActiView version and a TCP/IP client example.
Hyosung Joo
Thanks :D
https://www.linkedin.com/posts/neurospe ... 3t821cL4Pw
ActiView 10.2 for ActievThree with native LSL support will be on the BioSemi download page soon.
