Actiview display settings
jokebaas
Post by jokebaas »
Hi all,
Is there a way to change the colors of the data traces in Actiview? Especially the yellow assigned to the fourth trace has little contrast with the bright background. I tried adding a section [colors] to the cfg file, didn't work. Any suggestions?
Jo.
The plot color cannot be changed in the current executable versions, you will have to make the changes in LabVIEW (right-click on the chart --> show legend --> right-click on trace icon --> select color, or better use a property node with "active plot" and "plot color" and change the color by connecting the proper RGB number to the node).
