dummy question EEGLAB
For the function Compare/sum ERPs, when you select to highlight areas with p<0.05 significance, which areas in the graph are in fact significantly different. The ones marked in grey (shaded) or the white areas...I'm a bit confused by the semantics of ´highlighted´
