use more than 128 channels
shinyi
Post by shinyi »
We have mk2 A/D box with speedmode at 4. I think we should be able to use E1-32 to H1-32. However, when I plug in the cable to E1-32, the CM-in-range light went off. Also, when there is nothing plug in the AD/box, the Electrode Offset tab in ActiView software showed 0 to -262 in channel A to D, but zeros in channel E to H. Could you tell me how to set the hardware or software to be able to use E to H channels?
Shin-Yi
You have only 128 channels installed in your system. Additional channels can be purchased from BioSemi.
Best regard, Coen (BioSemi)
