We have two computers, A and B. Now computer A is used for signal acquisition, and computer B is used for sending start triggers.
In computer A, after acquisition and analysis, we need send some signals back to computer B, is it possible to send the signals(A->B) through trigger output?
In FAQ, it mentioned "The trigger output signals can be controlled with an extra independent LabVIEW thread integrated in the BioSemi acquisition software"
However, I did not find out the way to write out the trigger output signals. Anyone give me some clues? Thanks a lot.
						Need help on "trigger output"
Refer to ActiView Light (http://www.biosemi.com/download/ActiView604-Light.zip) for an example of the extra LabVIEW code needed to sent output triggers form ActiView to the trigger port on the USB receiver.
Thanks a lot.
After I read the ActiView Light version, I guess the function with name "usb_write" should be used for sending output triggers to USB receiver, is it correct?
And if "usb_write" can be used for sending output triggers, I still have no idea how should I make use of this function.
I noticed the input parameter of "usb_write" included a vector with 64 bytes, and have no idea how should I write exact data(eg. 255) to trigger out pins via this vector.
Could you kindly give me more suggestions? Thanks again.
[quote="Coen"]Refer to ActiView Light (http://www.biosemi.com/download/ActiView604-Light.zip) for an example of the extra LabVIEW code needed to sent output triggers form ActiView to the trigger port on the USB receiver.
Best regards, Coen[/quote]
						Thanks a lot.
