I use Windows 7 64-bit and I cannot launch the Cropper utility (in fact, Decimator and Reader too). Each time I run it, the message box pops out saying that it's "unable to locate LabVIEW Run-Time Engine". This happens despite I've installed both 32-bit and 64-bit LV runtimes  (version 8.6.1 and 2009, respectively).
I suspect that Cropper looks for 32-bit runtimes in the default directories of the 32-bit versions of Windows, while on 64-bit editions they're stored elsewhere. Is there a way to specify where Cropper should look for the files it needs?
Best wishes,
Marek
						cropper cannot find LV runtimes in Windows 7 64-bit
				jdspoorendonk
I want to use Decimator. But when I try to install LabVIEW 8.2. runtime engine I get an error:
"The Windows Installer is corrupt. To attempt to resolve this issue, please register the engine by running regsvr32.exe on msi. dll."
I do not really understand what this means but I could not find regsvr32.exe
Kind regards,
Jasper
Kind regards,
Jasper
				jdspoorendonk
The BDF file tools compiled for LabVIEW RunTimeEngine 8.6.1 are now available from http://www.biosemi.com/download/ToolsFo ... Engine861/
