Screen resolution for ActiView 7.0
ronitibon
Post by ronitibon »
Having installed ActiView 7.0 on a 64 bit machine with Windows 7, we would like to know how to set the proper screen resolution. In 6.05 we used the "lowres" option which was fine for our 1280x1024-optimal 19" screen. Using that resolution now loses the right side of the ActiView screen. What should we do?
Please wait till I have the other versions ready, see viewtopic.php?t=560. In the mean time, use the scroll bars and resize options in the current 700 version.
Hal
Source code for Actiview 7
Post by Hal »
I am also using ActiView 7 (on a 64bit Windows 7 machine), but I would like to access the source code (.vi). Is there a place to download this?
Just to be clear, the button to edit the source code is present, but when I press it, the .vi appears to be locked-off (Labview menu items for 'switch to edit mode', 'show block diagram', and 'save' are missing).
Regards-
Steve
Please download the full source code from: http://www.biosemi.com/download/ActiView701_VI.zip
You will have to have LabVIEW 8.6.1 (full development or professional) or higher installed on your PC to run and edit the VI's.
Hal
Thanks!
Post by Hal »
Thanks Coen,
This is perfect!
Steve
