I have to run an experiment where i use more than 255 triggers. So i need to be able to send signal in more than 8 bits. What would the best option be for this particular problem? Maybe i should introduce two consecutive triggers? Something else?
Thank you.
						More than 255 triggers
Use all 16 trigger inputs for 65,535 different triggers, see http://www.biosemi.com/faq/trigger_signals.htm. You may need to make a new trigger cable, in the standard Presentation cables only triggers lines 1-8 are connected, see http://www.biosemi.com/faq/presentation.htm.
