Combo Input
Alexandre
Combo Input
Post by Alexandre »
In my lab we have several biosemi systems, complete with a whole bunch of accessories. I am willing to use GSR and respiration belt, for which I found that we have purchased the sensors. There is a dedicated input called "GSR Resp" on our amps. The GSR sensor fits and works well, the respiration belt doesn't fit in this plug, as is has a central pin, so how do we connect it ?
I read in the doc of the belt that it can be coupled with other inputs using a "combo input" and special software that are supposed to come when the belt is ordered. We have 4 belts and 2 GSr sensors, and on both our amplifiers the input reads "GSR Resp", so it might be our case ?
What does a combo input look like ? So that I can look for it in our accessories. Also what are the specific steps I need to perform if using the belt and the GSR at the same time ?
Thanks a lot in advance for your help.
Alex
ps : couldn't find any reference to combo input on the forum or webpage
Re: Combo Input
A combo are two sensors connected to a single input connector. The standard combo's are GSR/PLETH and RESP/TEMP. You may have a custom made GSR/RESP combo, please contact your local representative for more information.
