Hello
I use switches, but can't see the triggers at the bottom of the Actiview screen. What can be the reason? What should I do?
Best
Boris
Triggers and switches
Re: Triggers and switches
In case of the switches connected to the (analog) ERGO input (swicth signal visble in ERGO traces), set the 5th line of the CFG file to:
RespSwitch=1 //0: standard ergo, 1: ergo 1 & 2 coupled to trigger 9 & 10, 2: switch input coupled to trigger 9 & 10
In case of the switches conencted to the (digital) SWITCH input (switch signal not visible in ERGO traces), set the 5th line of the CFG file to:
RespSwitch=2 //0: standard ergo, 1: ergo 1 & 2 coupled to trigger 9 & 10, 2: switch input coupled to trigger 9 & 10
Do not change anything else in the CFG.
Just to make sure. I will see triggers as bars at the bottom triggers window in ActiveView?
