Automatic Start/Stop the EEG recording
Jiti
Post by Jiti »
I want to automatically start and stop saving the EEG data. As explained by Coen in various posts, I have changed the following entries in default.cfg file
PauseOff=254
PausOn=255
In my stimulus presentation file, I specify 254 and 255 as the first and the last events. When I run the presentation, the file saving (unpause) starts automatically, but it does not stop saving (pause) automatically. I am trying to figure out why is this happening and how can I solve the problem.
Some more information :
When I view the triggers (in Decimal) in ActiView, the values are shown as 1 and 0 for start/stop saving triggers. The triggers for my other events are coded as 2,3,4 etc. in the presentation file. They are shown as 253, 252, 251, repectively. Also, in ActiView each trigger succeeds '255'. For example, as follows
1 255 ....... 253 255 ....... 252 255 ..... 251 255 ...... 0 255
I do not understand what does 255 represent here after each event. Or, is there some parameter that I need to set correctly?
I'd appreciate your suggestions and answers to above problems.
Jiti
Re: Automatic Start/Stop the EEG recording
The start/stop triggers declared in the CFG should be displayed properly in the "Pause On/Off" indicator in ActiView (left sidebar with the "About" tabpage selected (if not, then the proper CFG is not loaded).
The 255 codes after each trigger indicate that the trigger lines return to High instead of Low after each trigger (check with "analog" display of triggers). Correct in Presentation, triggers lines should all be Low between the triggers.
Jiti
Post by Jiti »
Thanks a lot, Coen. It works now.
