 I recently started using physiology for an experiment in my lab but I'm not really sure about the data. I used the IOM biofeedback system and the program lightstone monitor.
 I recently started using physiology for an experiment in my lab but I'm not really sure about the data. I used the IOM biofeedback system and the program lightstone monitor. The database is pretty simple and I have one column composed by the RR that I converted in bpm and another column that should be composed by the GSR but I don't understand if they are microsiemens or not.
The baseline data are composed by numbers like 5.7, 5.68, 5,62 while the experimental data goes between s to 7,22.
Is that possible that they are not microsiemens? The humans levels of GSR should be between 1 to 20 if i remember right.
