A new feature of Actiview Version 7.0 was "Response switches can now generate Triggers outputs on USB receiver. (in order to sent signals to stimulation software)". Is there any modification to make in the cfg file for this to happen, apart from setting <RespSwitch> from 0 to 1 ? Then, which output lines will contain the response box triggers ?
Thanks in advance for any information about this.
Dorothee
response box output triggers
Re: response box output triggers
RespSwitch on 1 (ERGO input) or 2 (SWITCH input).
Switch action will operate output triggers on pin 17 and 19 (output triggers 1 and 2), no further modifications needed.
